This is most likley a compressor,could get lucky and be able to have system recharged, there are many heat and ac repair places, you may also try this # 1-800-950-8835 if it just needs recharged, it wont cost much, either way you can call any above mentioned places and they will give you an estimate. Hope this helps
it will cost atleast 200.00, you can buy new ones different brands for less than 200.00 at home depot. I agree it should have lasted longer.If you want to persue getting it repaired call a ac or applaince repair place, if it can be recharged it would run no more than 60.00. Good luck and again i hope this helps
I called the number and they don't service this brand/model. Will it be pricey to fix if it is the compressor? It was manufactured in 2003, so I feel like it should last a little longer. Any other advice?
