I have an LG WM2277HW front load washer that is leaking from the bottom of the machine. It starts leaking as soon as the wash cycle begins. I have cleaned the drain pump filter from the bottom front of the machine but it did'nt help. Please help.
LG Front Load Washer WM0742HWA leaking from bottom toward right rear of machine - Have cleaned the front pump filter & tube, no blockage in drain hose, happens when drain, rinse cycle starts - Help please ?LG Front Load Washer WM0742HWA leaking from bottom toward right rear of machine - Have cleaned the front pump filter & tube, no blockage in drain hose, happens when drain, rinse cycle starts - Help please ?
You can't post conmments that contain an email address.
Re: I have an LG WM2277HW front load washer that is...
The most common reason for a leak on the bottom is a split bellows hose. You can check youtube using your model number above. Good DIYourself video on how to diagnose, part number and place to order. Cost is about 10 to 15 bucks.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - 189 reviews - $32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
If it is physically possible on your machine I would suggest that the door catch need adjusting, either that or it's broken but the door sensor still thinks it's OK ;-0)
Suggest a service call required ;-0)
Sorry,
Give a good clean around the door seal and make sure you close it firmly.This does usually fix it but you can also twist the door manually to help the seal.
