Washing Machines Logo
Posted on Mar 27, 2008
Bosch washer/dryer I have a Bosch Excell washer/dryer, model 24520GB. When washing the fault display F:17 appears, which I think in my situation means low water pressure, but it works. However, in the Dryer mode, after about a minute the dryer stops and the F:17 fault displays. How can I get the dryer to operate?
  • coolbeatph Oct 15, 2008
    i really have d same problem.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
430
Points
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
2answers
Hi. Have a Bosch Loggix 8 VarioPerfect WAS32440AU. It has been displaying a uPd code. Was hoping that you can verify the issue. TIA Brian.
First, of all it is a Bosch "Logixx".
Not a whisper of your fault code anywhere... go to this site and towards the bottom you will see a FORM to ask directly about your specific model AND your exotic fault code! Are you sure you have that "code" right?
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes
Then I found THIS bad news!
"There are a number of different version of the electronics used in Bosch Group made washing machines and washer dryers that are sold as Bosch, Siemens and Neff and most of them use the different fault or error codes when they have a problem or a spare part fails. This particular article relates especially to the range of Logixx washing machines that have an ENR number in the format of WAS****GB/** where the asterisks replaced by a number for each one."
Find a long list of fault codes here:
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Yours is not on the list? Still sure about that number?
Anthony
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 • Dryers
1helpful
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
2helpful
2answers
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
1helpful
My manual for bosch washer dryer wft6 is in norwegian and display lights flashing as fault but cannot understand it
you can now download the manual for this appliance direct from the bosch web site if its not listed there try the bsh home appliance web site when you connect it will ask you what language you want the manual in
good luck
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
2answers
BOSCH 1400 excell
find the punch hole on plate use pointed object stick in hole and turn
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Top Washing Machines Experts
john h
