it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
Carefully exmine the door seal for a hole or split, remove the clamp ring round front and pull seal of front of cabinet and check it carefully, if no sign of leak from seal, then it is going to be leaking from the plastic drum front of washer.
This will entail removing tye front panel.
Hope this helps.
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
