Question about Crosley CAWC529JQ Top Load Washer
Slow to fill the washer
Water just trickles in and takes forever to fill.....doesn't matter hot,cold or both
  • Crosley Master
  • 43,501 Answers
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing MachineSlow to fill the washer - 2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on May 10, 2010
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
heatman101
Mar 30, 2011 | Washing Machines
My washer seems is filling very slowly, and doesn't empty all the water out of the tub. I tried both temperature settings and it doesn't seem to matter. It will fluctuate back and forth on how fast it...
regarding your filling problem , most washers have small screen filters at the water intake, take your hot and cold hoses of of your machine and observe the fittings on the machine you will likely find the filters there they are just a mesh screen, remove them and clean , then reassemble this should solve your slow filling problem
May 08, 2010 | GE WPRB8050D Top Load Washer
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Low hot water pressure in old whirlpool washer forever to fill
If you have verified that it takes longer than 120 seconds to fill with water then you need to replace your inlet valve. You might be able to get away with just cleaning the screen but you should probably replace it. pn 8531670.
However it more likely you have a defective heater and the dishwasher is trying to obtain its optimum operating water temperature unsuccessfuly and thus stalling to heat water longer than it used to.
Mar 31, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Crosley CAWC529JQ Top Load Washer Logo
161 people viewed this question
Top Crosley Washing Machines Experts
peter gittos
peter gittos
jdthefixer
Derek Bannister
Derek Bannister
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
