When I change it to channel three I can only get 1 channel .When I try to change the channel it goes back to no signal.
Simple solution to my av setup that I use to connect my receiver to two monitors so I can pick which monitor I want to use for games or movies while using the other monitor for my PC. This product also solved an HDMI/HDCP issue in another room on the end of a long HDMI run into a projector. Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
