How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Adjustable Color Temp.
The Adjustable Color Temperature feature lets you adjust the color balance on your TV, depending on the type of light in the room, such as direct sunlight or artificial lighting.
On your remote control there should be a button that lets you change the picture mode, IE. Rich, Personnal, Cinema, Sport etc...
Yes you could look for the capacitor that is leaky, probably in the 200v line, or you could just open back and turn up G2 screen control on the Flyback. You have Screen and Focus on this black transformer with a long anode lead going to the picture tube of set. Becareful, High Voltage!
hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
