I just purchased the Philips PH62080 microphone. I plugged it into my computer as I need to record my voice on a computer program. The volume is all the way up, and there is still no sound coming out of the microphone and nothing can be recorded.
I know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
This same thing happened to me. All I did was plug the mic into my keyboard, turned the mic volume to max, and turned the mic on. Then, I grabbed the part of the mic where the cord goes in, and started turning it. I turned it left and started hearing noise come out of the mic. I kept on doing this, until sound came out of the mic. I did this, and now the mic works again. Hope this helps!
cant here sound
My microphone doesnt work when I plug it into my pc port. what is the problem?? ---I know its not my mic because it works on my karaoke.
Do I need to install drivers for this?
i cant get sound out of my new Philips PH62080 Uni-Directional Microphone Microphone
my microphone was working before but last 4 days now sound what can I do?
