Question about Asko W640
We have a problem with our W640. The power shut dowm every time we put the contact in, and we cant open the door bacause of the power. is there any buttom i can push? and were is it?
  • 69 Answers
You can open the door manually: Open the filter flap at the bottom left of machine- you will see a red loop attached to the machine by a screw- remove this screw and pull down on loop- door will open. If you go to www.asko.com.au, click on "customer care", then "manuals", and type in "W640" in the "Search product" box, you can download the entire manual for your machine. Chapter 13 has picture showing how to manually open door. However, if the machine is tripping the power when switched on, you obviously have some electrical fault in machine, which will require the attention of a technician. At least you can get the clothes out though!! Happy fixing!!
Posted on May 11, 2010
Anonymous
SOURCE:
My hotmail comes up cant auto dowm Load or upload not working and also a script error i cant get rid of on everysite just about
Hii Annette,
You can contact to Hotmail experts on (1-888-361-3731) for your problem If you want to contact Hotmail technicians you can contact on (1800-626-1046).
Thank You.
Oct 24, 2016 | Computers & Internet
Cant open doors without fob, put new battery in still not working, can'get into car
Check to make sure the battery is inserted correctly, the tabs are making good contact, and the polarity is correct. Check to make sure button contacts are clean if visible. Ensure case is snapped tightly shut.
Feb 27, 2015 | Cars & Trucks
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
IT IS NOT INDESIT 123. IT IS INDESIT 133
its prob your inner door catch or door striking plate the inner door catch has a bymetal strip inside that looks the door they wear out but if the striking plate is worn on the door it will also stop the inner catch to lock it is better to replaice both at the same time they are not to expensive to buy and easy to fit just turn off the power to machine unplug take the top off and you can get your hand dowm the front where the inner lock is undue the two screws which holds the inner door catch lift out and unplug the lock plug in new one and put back you will see how to replaice the outer door catch best to take the door off and lay flat
Nov 06, 2011 | Indesit W 123 Front Load Washer
Child lock is stuck on and machine won't start
Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
Feb 01, 2011 | Asko W640
Blower fan will not shut off, radio quit working, side doors will not open electrically, heated seats quit working . Not all of these happened at the same time.
First thing I would check is the main power distribution center for the circuit breakers,relays and fuses. Use a test light to see if power is at all the connecting points, put fuses in place of breakers to test them. Burned contacts inside will make them "click" but no power will go to the circuit. You can take the cover off of a breaker and look inside at the contacts and clean them with emery cloth or fine sand paper. Relays are the same only boxy in shape. Contacts will also stick shut and not disconnect like in your blower fan problem.
Hope this helps, Craig
Dec 23, 2010 | 2000 Chrysler Town & Country
Preheat comes on then clicks out on a 1.9 golf. so i cant pre heat new glowplugs wire has power for a split second
YOU DO KNOW THAT THE DRIVERS DOOR STARTS THE HEATER PLUGS WORKING....and the routine is, open door,sit in seat, shut door,start car, put belt on,if you take your time doing ANYTHING else the heater WILL have started and switched off.NOW,if that dont work,you will need to get a diagnostic computer to tell you where the fault (if any)lies.the timer is inside the ecm.not adjustable.
Oct 26, 2010 | Volkswagen Golf Cars & Trucks
2006 Chevy Uplander. The power sliding doors won't shut
2 possible solutions. First clean the door pin contacts(multiple spring loaded pins on door side and matching plate on body) with a scotch pad until shiny gold color again. Second the rear edge of the door should be 1mm inside the body opening when closed. If those are correct it is going to take a software download from a dealer to the door control module to fix this. Otherwise you will have to pull the psd fuse and breaker from the right side dash fuse box.
Jun 23, 2009 | 2005 Chevrolet Uplander
Locked back door of toyota 94 corolla
There is a child safety lock in the door jamb. Unlock the door and open it from the OUTSIDE and look for a small sliding switch somewhere along the edge of the door where the door makes contact with the body when shut.
Oct 16, 2008 | 1994 Toyota Corolla
Washing Machines Logo
250 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
