Garden Logo
A
Anonymous Posted on May 09, 2010
My stihl fs36 Whippersnipper continues to flood what is the cause
My Stihl FS36 Whipper snipper continues to flood What is the cause?
Curtis Sewell
Level 3:
  • Garden Master 7,482 Answers
  • Posted on May 15, 2010
Curtis Sewell
Garden Master
Level 3:
Answers
7482
Questions
Helped
1941401
Points
24946
Your float adjustment in the carb needs to be reset, or there is trash under in inlet valve in the carb.
If the float is set wrong or trash in the inlet valve then that will cause the problem of flooding,
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
1 Related Answer
Anonymous
  • Posted on May 22, 2011
SOURCE: my stihl fs36 Whippersnipper continues to flood what is the cause
needs a carb kit with needle valve $20 at a small engine store
1helpful
Have fitted a new spark plug but still no spark fs36 stihl snipper
Check the stop switch and wiring is ok and if nothing found it is probably the ignition module.
If it is fitted with plug connecting cap of the suppressor type it is well worth removing it and testing again for a spark. The spark usually isn't very strong at pull-start speeds so it is best tested out of bright daylight.
Stihl fs 35 recoil
Stihl don't make an FS35 but they do make a FS36
this should help.
http://www.mediafire.com/view/yleara73l4w78xa
Where do I attach the stop switch wire on a Stihl FS36 weed trimmer?
one end goes to the switch the other end goes to the ignition module
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
4helpful
Need a diagram for fuel line placement on Stihl FS36 line trimmer
Hi Lee Miller
Hope this is what you need
Please take time to rate me
Bud
I need to see a fuel line diagram for Stihl fs36 trimmer
Hi Lee Milleer
I hope this is what your looking for
Bud
2helpful
What is the airgap for the magneto on a stihl fs36
normally .16 or a match book cover between the two would work.
Mar 27, 2010 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
