I have "installed" a new SATA hard drive. My Master is a WD 80 IDE drive. For some unknown reason, when the SATA drive is plugged in, all I get is the CMOS recognition screen. The computer won't boot to the desktop. The screen remains blank. I am running XP Home Edition SP2. The problem does not occur when the SATA drive is disconnected. I was able to load XP onto the drive when it is run as a stand alone drive. The computer works fine with the drive as a stand alone. Any help is appreciated.
Could have something to do with the IDE being set to master.. It has been known that sometimes the SATA drive will take over as the master.. Try changing the IDE drive to cable select, and see if that helps.. If not, change the SATA to slave.
If that doesn't work, post your motherboard model# along with your bios name/version.. and we'll go from there.
As a side note: When they are connected the way they are now, does the bios show both drives?
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
during the boot up process you will see on the screen for a short time press a certain key to enter set up press that key to enter set up
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
