Behringer Pmp3000 16 Channel Audio Mixer Logo
Posted on May 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I buy a fuse and fuse holder for my Behringer pmp 3000 power mixer - can anyone tell me pleas Lyn
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on May 12, 2010
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2250374
Points
16163
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
2answers
We are trying to purchase a pmp mixer for our church choir. What's the difference between the pmp 3000 and the pmp 4000? Thanks!
The answer is "Not Much"... they upped the rating for power out and added 1000 to the model number... I don't know of any circuitry difference between them... it would probably be minor. Functionality is the same.
I believe I only need the cap that flush mounts on the back of the pmp 3000, not the whole interior fuse holder.
Sorry, but the fuse "boat" is not readily available. You USUALLY have to buy the whole holder... the whole thing is around $3 from Digikey.com. Many are manufactured by SCHURTER.
Where can I replace a fuse holder for a pmp 3000. Is this mixer the worst piece of **** mor what. Seems all they do is malfunction.
moz-screenshot-2.pngBuy this kind pf fuse holder is very easy to install. But rememnber you have to desolder the old one, solder extension wire to the board and to the new fuse holder. Make sure the new fuse holder meets the standard of the old one. And of course can hold the right fuse for your machine.
http://www.allelectronics.com/make-a-store/item/FHPM-31/3AG-PANEL-MOUNT-FUSE-HOLDER//1.html
4helpful
I have a behringer PMP 3000 mixer, on e of the channel is gone, it is not under warranty, can you tell me who can repair it ? what causes the channel to blow.
Often the A channel power output blows. CEASE using the unit immediately until repaired as continued use can have additional damage to power supply.
Any problem with speakers can blow the channel as there is real weak insulation on a multi-layer circuit board in the rear most amp (channel A). It burns and takes out three transistors on the HCA2400 module inside.
ALSO read my tip on here regarding a hazard of Behringer PMP units due to the channel A connection when using Speakon to 1/4 inch plugs or adapters having the BARREL being the hot lead instead of the TIP of the 1/4 inch plug. Short that barrel to ANY ground and goodbye channel A.
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
I HAVE A BEHRINGER PMP POWERRED MIXER 5000,I LOST ...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
Good luck..
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
I need a fuse and fuse holder for my Behringer pmp 3000 mixer
It sounds like you need just the fuse carrier...
This is as close as I can find:
http://mouser.com/ProductDetail/Schurter/62002300/?qs=sGAEpiMZZMv1TUPJeFpwblxZ%252bgbqW48rbR6t5kzh87o%3d
The only way to get exact is to go through Behringer or get an exact part number and manufacturer.
Disassembling your unit to get at the part would be a lot of work. I have repaired three of these and am familiar with the unit.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
