Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
THEN
Connect a LAN cable from the Netgear to the LAN port on your
computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the default admin password and configure
the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2
encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this
link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
