Due to poor water pressure at the dispenser, replaced the water valve. The water pressure is still low and the ice maker doesn't work - no water in the icemaker. Water line looks good. Also removed the water filter thinking that might be the problem but still low pressure. Just have the cap on for now. Any suggestions? Thanks!
SOURCE: No Water in Ice Maker
before u call a repair man i would unplug the fridge for 12 hours about depending on weather to let ur line unfreeze if thats the problem the dispenser in the door and the one to the icemaker are two different lines so just because the door works with water dispensing doesnt mean the freezer line isnt froze over
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
SOURCE: kenmore indoor icemaker frozen wil not dispense ice
Hi. I need more information to help you with your problem. Model number and a better discription of your problem. Will not come out of the ice maker itself or the ice dispenser? Thanks, Mack
SOURCE: icemaker
There is a water fill adjustment on your ice maker the normal fill time is 7.5 seconds...
the adjustment screw is on the side and in the middle of the head..
•Turning the water level adjustment screw
will move the contact in its relationship with
the contact ring segment. This causes the
contact to vary the time that the water valve
is energized since the contact ring is tapered
at the end of the fill time.
•Turning the knob or screw clockwise
decreases fill - counterclockwise increases
the fill amount.
• Only one revolution is possible with the
cover on, due to a stop molded on cover
360o will affect fill by 40cc - 180o varies
the fill by 20cc.
•if you need more adjustmnet remove cover
• Further adjustment could damage
module.
Hope it help please let me know if it does...
