Question about Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix dmc-fx01 won't focus
Camera will turn on, lens extends, but then it puts itself into telephoto mode and will not focus or allow picture to be taken. Camera was dropped.
  • 3 more comments
  • Anonymous Jun 22, 2008
    I took a picture, then when I went to preview mode, it just froze. Now, everytime I turn the camera on, at normal picture mode, it automatically zooms in, and doenst allow any pictures to be taken. On SCN mode, the screen keeps showing all scene modes non-stop. What would be wrong with this cam?
  • Anonymous Jun 28, 2008
    it seems like the toggle is stuck on the zoom in position!  what to do?
  • dogday4u Aug 11, 2008
    Yes, I have the same problem too!
    I turn on the cam, it goes to max zoom automaticaly and freezes for any other tasks. It also winds through unstopably all the shooting modes as in a preview, but will not respond to anything I try to do.
    Does anybody out there has a solution?
    Thanks
    Tom
  • Anonymous Sep 02, 2008
    I have exactly the same: the scrolling menus in SCN mode and can't take any pictures. Has anyone tried to contact Panasonic? No response sofar when filling out a web form... The camera was not dropped!
  • Erickam79 Dec 27, 2008
    Lens extends even when it is turned off. When it is turned on, picture can not be taken. Error message appears that says "Shut off camera, then try again." When I do so, the problem persists. Any suggestions?
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Posted on Sep 02, 2008
6ya staff
SOURCE:
Vivitar 35-200 macro FD mount lens for Canon doesn't extend to telephoto. It seems to be stuck at 35mm. Any tips? Disassemble, special buttons, tricks?
Did you try putting the camera and lens in Manual Mode and focusing by hand? On Many cameras there is a tiny switch on the lens that limits your focus ability to either FULL or LIMIT.
Nov 13, 2013 | Vivitar Cameras
Taking pictures with x3 telephoto lens
may be there is some problem with your shutter speed and lens
Jun 18, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
My pl1 camera has blurred pictures but when lens taken out, its ok.
Are you using an auto-focus m4/3 lens? I have about 20 lenses for this camera and only 1 of them is an auto-focus m4/3 lens. I have an adapter so I can use my 4/3 lenses on it in auto-focus mode along with other various mounts (including cctv) that do not support auto-focus. So if you are using a non-auto-focus lens, you will need to manually focus the pictures.
If you are certain it is an auto-focus lens, are you sure you have it set to auto-focus?
What settings do you have your camera set to (aperature mostly is what I'd like to know)? Try adjusting your aperature to be small (to increase your DOF).
Also what lens are you using and what is your focal distance? It could be your lens has a larger or shallower focal distance than what you are trying to achieve (like a macro lens doesn't work that great for landscape photography or a telephoto lens doesn't work great for macro photography).
Last thought: is your lens or sensor dirty? A dirty lens can cause focusing issues if it is REALLY dirty and a dirty sensor can too (sensor is a bigger pain to clean. I strongly recommend taking it to the pros as they scratch really easily). Dirty lenses can be cleaned with a blower and a lint free cloth and rubbing alcohol if those 2 things don't clear it out.
Mar 03, 2013 | Olympus E-pl1 Pen Digital Slr Camera w/ M....
Canon rebel T3 focus problems
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
Sep 01, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
Autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Blurry pictures
Just returned from trip to Cuba..most photos taken outside and few inside...all photos were exc. or good except the ones I used with the telephoto feature. Had I left it on the W feature,these photos would have been ok...also make sure the focus ring lens adj. is not on the macro imaging feature..found that focus ring lens setting sometimes moved when I put the camera into its case
Pancho-poppa..
Feb 10, 2008 | Jazz DV-179 Digital Camera
Very long shutter release delay
This is weird, usually shutter delays are caused because camera is trying to focus first, it really shouldn't happen after pre-focus. do you have a manual focus mode? if you do, try it and see if it works. if you dont, I would still suspect it some kind of focusing problem, but unfortunalty i have no idea how you can fix it yourself.
Mar 10, 2006 | Canon EOS-20D Digital Camera with 17-85mm...
Panasonic Lumix DMC-FX01 Digital Camera Logo
505 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
