Expert
- Posted on Jun 04, 2010
Re: I locked my nikon 50mm lens aperature ring to the...
Sounds like the coupling pin on the body is missing, Try a diff auto focus on the body, If it still does it then I believe that\'s the problem, On the body next to the lens mount, About 7 o clock there should be a lever that couples with the lens when is is at f22 or larger
Just to be clear, when you say "the appropriate setting" you do mean f/22, right? There's also a small orange slide switch on the lens which needs to be slid toward the camera body. Is it?
