Hi
I'd like to use my f31fd as webcam or at least I'd like to record video directly to the computer.
What soft I need?
I can't the soft that comes with the cd (Finepix viewer ) becasue my PC has Windows 7.
Fujifilm site has an upgrade for win 7 but you must have first the cd installed on your computer but It refuses to be installed.
SOURCE: The AutoPlay Wizard does not launch when I connect my camera
We suggest running the Microsoft AutoPlay Repair Wizard utility which is available as a free download from the Microsoft Download Center. The AutoPlay Repair Wizard scans your computer devices to find defective AutoPlay settings, and attempts to fix those it finds. To download this utility, please go to the Microsoft Download Center and enter "AutoPlay" in the Keyword box.
If the removable disk does not appear when you open "My Computer" in Windows, it is possible that the USB drivers are not installed correctly. Update to the latest version of FinePix Viewer (including the USB drivers). To update FinePix Viewer, you must have the software from the CD-ROM bundled with the product (Utilities for FinePix) already installed. As an alternative method to updating the software, you can also reinstall the USB drivers. The USB drivers can be reinstalled by installing the software from the CD-ROM again. If the removable disk is still not displayed after the above measures have been taken, check the following: Windows system checks 1. You should be using Windows 98, Windows 98SE, Windows ME, Windows 2000 or Windows XP. 2. The Windows XP USB drivers are supported as standard system drivers but are only compatible with Software for FinePix versions 2.0 or later. If you are using an earlier version of the CD-ROM, an update to FinePix Viewer is required. 3. The software cannot be installed properly from "Scanners and Cameras" in the Control Panel. Digital camera checks 1. Check that the digital camera can play back images on its LCD monitor. 2. On digital cameras with the PC Camera function, select "DSC" as the USB setting. (Refer to the Owner's Manual for your camera for information on specifying the camera settings.)
SOURCE: finepix viewer
I have searched over time, I never have found that software for free on the net. You can get a CD off eBay for a few bucks
SOURCE: Can i use my Fujifilm FinePix S5600 as a webcam?
Acording to my research, i do not think that you can.
