It is critical thet you replace the cooling fans! The imagers will be damaged if you don't. The focus issue is possibly contaminated a lens, dust or vapour.
replace the color wheel and remove the fan blowing on the engine, its forceing dust into the wheel area, the wheel will last about 14-18 months, removeing the fan will extended life 2-4 years, there will be no heat issues with the fan removed, some models or later production runs will not have this fan
If Fan stops running Lamp will not Light and TV will not come on!On your Menu you should have in there a listing for Lamp Timer it should tell you how many hrs you have on Lamp and Ballast Board is what turns Lamp on if you need Parts Call Encompass 1-800-638-3328 or UED 1-800-648-6657
Your problem besides color wheel is the Ballast Board this Board is what turns on Lamp and be sure to CK cooling Fans if fan that cools Lamp is defective Lamp will not light,nor will set turn on!Call Encompass Parts or visit their website they should have listing for parts to your TV 1-800-638-3328 and heres another company you can Call UED 1-800-648-6657 If you need to know anything else let me know.
God Bless and have a Wonderfull Day.
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
There is a software patch availabe to increase the thermal cut off temperature. Can only be programmed using the Loewe Cablemax kit. Another solution is that the fans at the back all blow into the tv, reverse one of these fans, this gives a flow through the cavity. Remember to remove the filter from the one you reverse.
