your rca does it have a button for cable. then you can program your tv remote to work with the cable box. go to the manual and try all the codes for rca tv. if this does not work then you have to try it manually. have them give you a different adapter. it might be in the box or remote.
I assume the control panel on the tv still works correctly?
If so i would think you have a remote problem.
If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
THE ONLY SOLUTION IS TO ORDER A REMOTE FROM MEMOREX. I HAVE TRIED FOUR DIFFERENT UNIVERSAL REMOTES AND CONTACTED THE MFGS HELP-LINES WITH ZERO SUCCESS. I FINALLY GOT SOMEONE AT MEMOREX TO ADMIT THAT THEIR REMOTE IS THE ONLY ONE THAT WILL WORK ON THIS (MT2024) SET. "$88.OO".--- WHAT A DEAL FOR A NEW TV! IF YOU BREAK OR LOSE THE REMOTE, THE FRUSTRATION QUICKLY BUILDS AND ADDS UP TO MORE THAN $88.00
