Maytag Neptune top load, non agitator washer less than 3 yrs old: last two washes have leaked the water on the floor. After 1st leaky wash, rechecked all connectors in back of unit and wall. All were dry and secure. Water draining out of the bottom? Leak in washer tub?
Same problem, only I see that the water supply is blowing pressurized water into the lid--and the plastic nozzles are about 1/4 inch or 1/2 inch OUTSIDE the lid/drum enclosure. BY DESIGN. They end, but one would think there'd be some rubber nipple/seal for these things...the lid is locked closed, but (like a Whirlpool stove) the whole top of the water lifts offf, and it is EASY to see the problem...more concerned about finding a suitable repair.
The water "jet" has backspray that is wetting the wiring, but the problem is that 1/2 cup or so goes down inside the frame, but outside the tub...the whole inside of the frame is wet.
I need some kind of rubber seals. Where to send pictures?!
Water leaks out bottom of unit when turned off
