HP 3600N Printer 10.10.01 supply error
Simply re-use the tiny chip from the old cartridge.
you will need a thin scrwdriver to gently prise the old chip out from the hot melt glue holding it.
then use the chip from the old cartridge and secure with a dab of hot glue.
then use the maintenance menu to set the printer to run when empty override and set to 50,000+ copies if requested.
the printer will keep running until the cartridges are physically empty.
using the old chip means you have a chip that will at least run.
change the cartridges when a particular colour starts to fade.
Replece the cartridge Cyan...
Regards!
The printer cannot read or write to at least one
print cartridge memory tag, or at least one
memory tag is missing.
1. Open the front door.
2. Remove the print cartridges,
reinstall them.
3. Close the front door.
4. Turn the printer off and then on.
SOURCE: Error code 51.23 on HP 3600n printer
Turn off the power by using the power switch, wait at least 30 seconds, and then
turn on the power and wait for the device to initialize.If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the
device on.Laser scanners are not replaceable.Replace the engine.
all the best
SOURCE: LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
i have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
Tried that and still have the problem
tried that still have the same problem.
