Treadmill only works for 15 seconds and then stop. After that theres an error message saying Error 2- A0... Any suggestions?
1) If the the belt is moving during that time then stop I would suspect that speed sensor maybe defective. Replace the sensor
2) Now if their is no belt movement then either Motor Control board or Drive Motor is defective. Do Motor Test
I would check the drive motor first to eliminate an expensive component, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) if that is accomplished then the only other component to be replaced would be the Motor Control Board. Call Matrix for parts @ 1-866-693-4863 option 3
1 )Locate
the reset switch on the underside of the treadmill console. Usually
the button is large enough to trigger with a pencil eraser or Q-tip.
Plug the treadmill plug back into the wall. Use the Q-tip to press
the reset button. It may be necessary to hold the reset button down
for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the
reset button one more time with the Q-tip. "CL21" should
appear on the screen. Press the enter key. The display will change
again and show "CL22." Keep pressing the enter key until
the numbers cycle through to the number "CL26." Press enter
one more time. The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
