HAVING HARD TIME FINDING THE CODES FOR THE ZENITH DTT900 DIGITAL TV CONVERTER SO I CAN USE THAM WITH MY ONE FOR ALL TV REMOTE . E MAIL [email protected]
Hold Power and press Channel Up or Down. There are 150 manufacturers, so if you don't get functionality within 150 presses in one direction, you're SOL.
I own a Zenith DTT900 Converter, along with a briefcase full of universal remotes. Most of the remotes I own do not work with the converter, but here are the codes and remotes that DO work that I know of: All are programmed under the satellite receiver button.
Phillips PM6225 6 Device Consolidator--Code 267, which is listed as a Zenith satellite receiver
Radio Shack Model 15-135 HDTV Pro Remote-- Code 01414, which is listed as a DirecTV satellite box code, as well as an LG satellite box code
Radio Shack 8-in-1 LCD Remote Model 15-100--Code 01414, which is similar to the model 15-135.
Zenith 6 Device Universal Learning Remote Model ZN620--Code 267, similar to the Phillips remote listed first.
This may not be a direct answer to the One for All remote you have, but the remotes I listed are stiil for sale as of 4/08, so at least you know some currently available remotes that can dothe job....
My grandchildren lost the DTT 900 remote control. While at Harbor Freight yesterday I saw a giant universal remote control for about $8 hanging on the wall. Told my wife this would be a nice joke type gift for them, not really expecting it to work. But, it does work!. The remote is a model YK9001 with a suggested retail of $39.99. Its about 5 inches wide by 12 inches tall. The instruction book is tiny 2.5 inches by 4 inches. I followed the instructions for searching for a code under SAT button. Bingo! it works everything on the Zenith DTT 900. I would bet you find the remote on Harbor Freight's web site. I own several universal remote controls including the OneForAll URC-8910B02, but am waiting for from the update service. Here is a cheap, big, giant remote from a bargain tool store that works. I used the retrieve method and it reports 212 under the SAT button.
Dave
I just posted the info on the Giant Remote and looked at the Harbor Freight Web Site. My remote doesn't have the same model number or the name Emerson. The following is how it is described on their web site. The photo is exactly the same as the YK9001 that I had success with.
Emerson# 1606917
ITEM 95816-8VGA
I can confirm that the correct code for this is 1415 - a few more bits of information, though. You need to get a wav file to program that code into your remote, and the phone number in the manual doesn't work any more. I was able to track down a new customer service number (Dec 12, 2008), which is 330-405-8655.
When programming code 1415, you have to change the device type to "video accessories" - when programming, after selecting code select and choosing a device button, use the up/down arrows to choose the different type (type "video") - otherwise it will NOT find the code! (This was not described in the manual, had to get it from the customer support folks).
Hope that helps,
Mark
Have a zenith universal remote and i want to programe a viore telivision but can't find the manual and i need a code please?
On a One For All Universal Learning Remote URC-8820, the code that operates my Zenith DTT901 is 1415 on the cable button. This is the code for LG HDTV Decoders. If you don't have the same remote, I'd look up the code in your remote's book for LG HDTV Decoder (also listed under "Video Accessories" in my remote's setup book.)
All except one of the key functions work to control the Zenith box by setting that one code on my universal remote, including zoom, info, programing menu, recall, mute, channel, volume, etc. The only function that I may have to program manually is Simple Guide.
Hope this helps.
If you have a RadioShack Universal Remote look here:
http://dostuff.radioshack.com/files/DTVConverterFAQs.pdf
This includes instructions for Zenith and Digital Stream boxes sold at Radioshack.
For the the Zenith DTT901, the instruction is to "Set the remote’s operation mode to TV or Set-top Box and use the LG or Zenith codes listed in your universal remote’s user manual."
With a Sony Blu-ray remote, such as RMT 105, the code for a Zenith TV turned out to be 11 .
DOES ANYONE KNOW THE CODES FOR ZENITH DTT900 DIGITAL TV CONVERTER , WONT TO USE MY ONE FOR ALL REMOTE CONTROLLER WITH IT , BUT CAN'T SEEM TO FIND THE CODES. THANKS ! MAUSER
I too am looking for that DTT900 code.
I have the same problem
want to use it with a slingbox, but what is the remote control control code?
Can't get my RCA universal remotes to find any code in the auto search on the Zenith DTT900 converter box. Is there a code for the Zenith DTT900 that I can enter to make my RCA universal remotes work to control the converter box?
Radio Shack Remote will not connect to the Digital Stream Box Converter.
I tryed many codes. Any Ideas.
0052 no, 0899 no, 267 no..
MY CODE TO PROGRAM MY REMOTE TO TV WONT WORK
ZENITH REMOTE TO A ORION TV
i can find the book that tells me the tv codes
dtttuner
I have a Zenith dtt900 and want to program my Sony remote to work with it. I have a rm-v310. anyone have a solution
I can only tell you what worked for me just now... I haven't tried the code in a different configuration yet because this works for me. From Sling Setup Assistant then choose video sources. Mines Antenna In.I choose External Box that outputs to channel 3.
Type of device = Satellite Receiver
I use a zip code for a major area 30 miles from me which for me is 48192. This has all the channels I can receive in my area as well. Under Service Provider I chose DirectTv Detroit Satellite. For Manufacturer I chose Other and for Model I chose Other. I chose Yes for is this the correct channel lineup. Then the option comes to choose a code... Code 6 works for me. It shuts off the box. I turn the box back on manually... set the control for just pushing number 5 turns on channel 5 and now I get all the channels with control. I have a SlingBox Pro... using the new program 2.0. I have my rooftop antenna connected to the Antenna In on the Zenith box. From the Zenith box out to the In on the SlingBox. From the Out on the SlingBox to the In on my TV. I am also using the IR controller on the Zenith Box and plugged into the Slingbox. The correct placement of the IR controller is between the Blue Light and the 2 channel up and down buttons. Get a flashlight and you can see the little bulb inside for the exact placement.
If I had time I would do some experimentation now... we know code 6 works for satellite receiver with other manufacturer and other model using DirectTv. Maybe this will work using a satellite provider in your area.
STB7766G1
