If you are consistently not getting the person on the other side hearing you (every time you call) it might be a bad mic, or some other malfunction with the phone. However, if it is working sometimes, and occasionally they cannot hear you that is somewhat typical with mobile phones. Try a headset and see if that corrects the problems if it is happening every time. If the head set corrects the problems then it is likely the mic is bad as stated in the other post. Good luck.
Testimonial: "Thanks , I discovered it was a dirt problem within the microphone . Problem solved."
The microphone in your phone has probablt gone bad, check to make sure it is not plugged with dirt; if not have it checked out at your carrier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Testimonial: "Thanks,now I need to find the microphone on my phone so I can check it for dirt ?"
SOURCE: W700i phone ,when call is picked up, unable to hear the voice of other person sometimes...
Yeah well better take your mobile for service to a Sony Ericsson showroom..Even i had a same problem in sony w810i which got fixed after a service..Thank you!!...
SOURCE: when making or recieving a call on my samsung
When you make or receive a call you are unable to hear the person,
Because the hearing speaker on your phone would have gone,
try talking on a Loudspeaker and get the hearing speaker checked from the nearest Service centre.
Thank you for using Fixya
SOURCE: The caller is unable to hear me. Please help!
thanks for the comment, and thank you for using fixya.
Take care.
