Question about Phase Linear UDV9010 Car DVD Player
Brake bypass code
I need to know what code bypasses the brake for the new phase linear uv8020. this is a new in-dash one so it is hard to find. I need to know soon. I hope someone has the answer
  • erica0317 Aug 01, 2008
    I have the same problem hjust bought the thing cant find any bypass code. Is the pink wire the only thing that works or can u do the same 543210 one even the 1246 please help im a girl and dont want to get suckered into any of these dumb people trying to charge for it. Thanks in advance
HOOK PINK WIRE TO A SWITCH THEN FROM SWITCH TO GROUND. PUT DVD IN ,WHEN WARRNING SCREEN APEARS, TURN SWITCH TO NON GROUND POSITION, COUNT TO 6 SLOWLY,THEN SWITCH TO GROUND POSITION ON SWITCH. IN ABOUT 3 SECONDS YOU SCHOULD SEE MOVIE IF YOU GOT COUNT CORRECT, IF NOT WAIT ALITTLE AND DO AGAIN .ASLOW 6 SEC WORKS 4 ME,YOU WILL HAV TO EXPERMENT TILL U GET TIMING DOWN.THIS HAS WORKED FOR ME .I DONT NO CODE, BUT WLD LIKE 2 NO
Posted on Jan 02, 2009
  • 3 Answers
Yha splice the pink wire to the neg black wire it works
Posted on Dec 28, 2008
Why dosent it sound when you conect the radio to the spekers on my nissan maxima 2000
Posted on Nov 08, 2008
I just got this same unit on thursday of last week and put it in myself. All you have to do is ground the pink wire out and it will work without having to put a bypass code in. Hope this works for you as well.
Posted on Apr 20, 2008
6ya staff
SOURCE:
Phase linear uv8020
you probably have constant power running the radio. do you have constant and ignition wires from the radio hooked up or did you twist the yellow and red wires together? if this installation was done correctly than you the unit should power off when you turn the ignition off.
Mar 29, 2009 | Audiovox UV8020
Unlock region code on my Phase Linear UV8
I had the same problem and I was able to fix it myself. call me and I can help you over the phone 951-334-2297 ask for George.
Feb 14, 2009 | Audiovox UV8020
No remote....
you mean you are trying to pladvd's while driving??? if you are here you go thae the pink wire form the uv8020 splice it iwith the black wire neg power wire. and that should work if yo uneed picturs just let me know montoyafam1@cox.net
Nov 29, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear vu8020
put the pink wire to the ground wire and it will play video all the time.
Oct 27, 2008 | Audiovox UV8020
Phase linear uv8020
To change the region code on the UV8 you must have a dvd playing and 1. with the remote press setup 2. then enter 5, 4, 3, 2, 1. This gives you access to firmware menu. 3. arrow down to tools "system settings" (you should be able to use the touchscreen) enter on region a menu opens and select "0" to make it region free. You can also go down to the brake bypass menu here to to put in "off" mode so you can see movies while driving.
Sep 03, 2008 | Phase Linear UDV9010 Car DVD Player
Bypass the parking brake
forum.ecoustics.com/bbs/messages/4/338612.html
Jul 31, 2008 | Car Audio & Video
Need to by pass
There are two ways of bypassing the brake sensor in a Phase Linear UV8:
1. ground the pink wire using a toggle switch;
2. Use the unit's built-in bypass software.
a. Select "Tuner" mode (AM/FM);
b. Press the "Setup" button;
c. With the use of the remote, press 5, 4, 3, 2, 1, and then press and hold 0 for a couple of seconds or until the menu changes. d. d. Display should show hidden menu. Among the options would be to turn ON the "Brake override";
e. Press th "X" on the bottom leftmost corner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Televison & Video
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Phase linear uv8=jensen brake bypass code
from remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
Nov 16, 2007 | Televison & Video
Phase Linear UDV9010 Car DVD Player Logo
905 people viewed this question
Top Phase Linear Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
