Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My tv I have it on the highist you can go on the brightness what could be wrong.
  • Philips Master
  • 3,459 Answers
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
my tv I have it on the highist you can go on the - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
Accoustics solutions 37 inch tv colour fading and changing
Increase the color saturation to fight the fading and decrease brightness slightly. All of these settings are in the menu of the TV.
Jun 07, 2012 | Televison & Video
Xbox360 picture is too bright
I just had this same issue when i bought an Xbox 360 a week ago or so. Everything was WAY too bright but only on the Xbox. After some checking and rearranging of cords i found that the RF Modulator (adapter) i was using was set to the wrong resistance (Ohms) as i plugged in the Wii and had the same issue. I would say check the resistance setting and channel on the adapter, also making sure to NOT use "Y" rca cables to have more than one thing plugged into the same input.
Hope this helps ^_^.
Apr 10, 2009 | Microsoft Xbox 360 Elite Console
TV screen became a lot darker than normal.
Hi.
yeah, opened the front flap of the TV>menu> brightness> increase. Sorted. No problem.
ain't gonna bother asking any more questions on this forum..........no help at all .
cheers, Pat
Mar 30, 2009 | Toshiba Televison & Video
Analog tv with poor color and brightness
probably tshe picture tube; time for new set
Mar 28, 2008 | JVC AV-27230 27" TV
Mitsubishi WD52525 Brightness
Usually a bad lamp. If the lamp you replaced is new, then cleaning the internal mirrors (especially the small triangular one) and clean the projector assembly as well. The lamp ballast supply may be weak as well, but I seldom see this.
Mar 04, 2008 | Televison & Video
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
51 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
