Question about Midland LXT315VP3 (14 Channels) 2-Way Radio
How to unlock one of the units? - Midland LXT315VP3 (14 Channels) 2-Way Radio
    Scholar:
  • 47 Answers
When you say unlock, I am assuming you are referring to the key lock preventing you from using any of the keys on the radio.
On your device, there should be 5 buttons on the front face, the one on the upper left should have a picture of a lock and the letter "S" on it. Push and hold that key until you see the lock symbol disappear from the display.
If you have any more questions, you can either ask me and I will be more than happy to help, or see the User guide on Midland's website.
http://www.midlandradio.com/Resource_/OwnerManual/115/LXT300.pdf
(the LXT300 and LXT315 are essentially the same device, and have no functionality difference that I am aware of)
Thanks,
Mike
Posted on May 16, 2010
    New Friend:
To turn the lock off and on just press the "Menu" button and hold it until you hear a beep. It is then locked or unlocked. You'll see a "lock" icon in the screen when it's locked.
6ya staff
SOURCE:
Need unlock code for this radio VO817ov9199103
Latoya,
I am assuming that you replaced the factory unit with another stock Volvo head unit? If this is the case, you can pull the unit back out and get the unlock code off the label on the unit. If this is missing, you will need to go to a local dealer and have them reprogram the unit if that's still possible. Good luck.
Feb 11, 2014 | 1998 Volvo S70
I got nuvi 205w satnav cant remember code ulock it plz send me reset code plz
Hello. If you can't remember the unlock code, there is no master reset code. The unit must be sent in to Garmin to be unlock. Another way you can unlock it is by going to your Unlock location, the location where you first set your lock on your device and as long as you have satellite signal the unit will unlock. Other than that the unit has to be sent to garmin to be unlocked. You can call garmin customer service at 800-800-1020 to set that up.
Sep 24, 2011 | Garmin GPS
I am wanting to unlock a lg kg290 from orange to any network
Which Country's Orange Network France or United Kingdom(UK) orange Network lock?I have Unlocked my phone from United Kingdom(UK) Orange NETWORK lock using the Unlock code from here Mobile-Unlocker.com and Unlocked it,you can also unlock your phone there....
Jul 11, 2011 | LG KG290 Cellular Phone
I get an error of f 29 and my door won't unlock
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need unlock garmin c550
Enter your PIN number, or take the unit back to the "Security Location" and it will unlock by itself. You can then enter a new PIN unlock code.
May 21, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin c550
If it is the garmin lock, then you need to take the unit to your sercure area, and the unit will unlock. This should be where ever it was you set up the unit.
If you don't remember either. Then the unit has to go back to Garmin to be unlocked.
If It is locked up (Software) then remove the faceplate and press the reser button.
Hope this is of some help.
Ed
May 08, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot 33o
Did you try to upgrade your Garmin with 2008 maps? If you have the map registration code then you will have to go to garmin's website and get an unlock code. You will need the registration code and also the unit serial number before you can get a new unlock code. The unlock code is base upon your unit serial number and will only work with that unit.
May 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Map Unlock Code
Garmin normally replace your unit with a refurbished unit. Yes call Garmin and ask for a new unlock code. Normally they provide a new registration ID (yellow piece of paper with the unlock code for the latest mapsource map and accessories which it also included with the refurbished unit.
Jan 05, 2008 | Garmin iQue 3600 GPS Receiver
UNLOCK
Impossible to unlock without knowing the PIN or the location of the GPS when the PIN was activated.
Oct 22, 2007 | Garmin StreetPilot c550 GPS Receiver
Midland LXT315VP3 (14 Channels) 2-Way Radio Logo
188 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Gene Pitts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
