It all depends on how mission critical this NVR is, (and how much money you have to spend)
A good rule of thumb is the more redundancy the better, so in theory, if you have the money, you should buy the second NVR, however if you cant afford an entire second unit, you should look at doing hard drive backups of that unit.
If you have any more question, please let me know!
Thanks,
Mike
Testimonial: "Thank you for your immediate respond.The situation here is consider critical as our client is a government organisation.The NVR is the most highest important equipment in this project as it used to record the movement in 24/7. "
I can assist you only by providing you a great DVR and NVR software for PC called iVMS-4500 which is very popular into the app stores. Get it from here: iVMS 4500 for PC Windows 7 8 10 Mac Computer Free Download Techforpc com
SOURCE: Can't assign ip configuration to NAS 208
Run Fastora Assist, it should detect your NAS even if no IP address is assigned to the NIC(s). Make sure to connect all NIC(s).
SOURCE: My Nas Fastora T4
I had the same problem after changing the disk setup from RAID-0 to RAID-5.
If you remove some of the harddisks (keep at least one) before booting, the system comes up again and is reachable for config changes.
I also had problems then with LAN1 card (did not get a ip address from DHCP anymore, only 0.0.0.0).
So I connected the Fastora NAS to LAN2. I was very surprised that the fastora filer tool did find the Fastora NAS connected with LAN2 configured to a wrong fixed IP-address that wouldn't work in my network. Fastora filer was able to remote change the IP-Settings for LAN2 card and now all works fine!
Hope this helps any other Fastora NAS user.
