Toshiba 56HMX195 52" HDTV DLP Projection TV Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCD screen keeps freezing
Have LCD HD TV its screen continues to freeze, it tends to stop when it warms up, the top right corner the color is brighter.
Anonymous
Level 3:
  • Master 1,961 Answers
  • Posted on May 17, 2010
Anonymous
Master
Level 3:
Answers
1961
Questions
Helped
665638
Points
5692
1 or more of the cold cathode must have been busted, the reason why a portion of your screen is brighter. It could also be the ballast transformer. It is also the reason why your screen stops when it warms up. Deffective cold cathode and its ballast has direct effect on the power supply. Replace all deffective cold cathode and ballast, and resolder all terminals connected at the surface of the power supply board. Be very careful with the ballast transformer, its input is 12 volts and high voltage output.
Why does my tv led40 keep freezing when I try to watch iplayer
I no idea how I got this question I have not got a HD TV let alone smart. Is the format compatible on them both ?.I can not help apart from that sorry .??
Screen freezes
the electronics are failing after it has got warm. Replace the TV.
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
2answers
Where is the power button on the mac computer
The power button is on the back of the LCD screen in the lower left hand corner. You should power down by clicking on the Apple Logo in the upper left hand front corner and choose "Shut Down". If your screen freezes, you can power off by pushing the power button and holding it.
Screen freezes and then shuts off. This cycles every 1-2 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
TV freezes and now banging when turned on
Sounds like the problem is with channel 9. Is it an HD channel? Are you using cable, satelite or an antenna?
Switching between a 720 hd channel and a 1080 hd
The unit has an auto detection circuit to determine what signal is being input, it then processes it, however if the signal is altered (different channel) the TV will at times try to process it through the wrong resolution circuit causing problems. Change the input of the TV and then change it back and it will redetect the 720p instead of the 1080i and display it properly. Check with Sony for possible updates.
Crampy
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
DVD Player freezing
You need to take this back if you have the option. The picture freezing lets us know that the data stream is stopping. It will not work right again and it was just coincidental that you uses a diffrent kind of dvd.
Thanks
Josh
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
