Posted on Apr 01, 2008
Sony BRAVIA DAV-HDX265 Changing the region code
I need to change the region code of Sony BRAVIA DAV-HDX265 home theater system. Is there any successful way to do it?
I live in India & want to change the region from 1 to all in Sony DAV-HDX265 Hometheatre System. Is any one can help me.
  • 3 more comments
  • Anonymous Apr 15, 2008
    I have the same problem and any help will be wellcome.
  • _ALX_ Apr 21, 2008
    Have you found any solution? I have the same problem.
  • b_vamsi Oct 24, 2008
    I have the same problem,please help me
  • Anonymous Dec 17, 2008
    same except its hdx 576wf
  • Anonymous Mar 17, 2014
    How do i change the TV Region of my TV?
A
Anonymous
Dav-hdx665 only plays certain DVDs, why.
Check the region code. Or the laser beamer is dying.
How to take off protector mode
the amp is bad and the main board will need to be replaced.
1helpful
Some how i accidentally child locked my Sony DAV-HDX265. how do i unlock it.
  • AH, well lets fix that.
  1. Press "System Menu"
  2. Press the Up arreo ^ or dowm arrow v repeatedly until "CHILD LOCK" appears.
  3. Press ^ or v to select a setting for "OFF" or "ON."
  4. Now press the "+" button and the setting is changed to your selection.
  5. Press "SYSTEM MENU" again to exit.
  • To remove a disk while child lock is on
  1. Press the "eject button" on the remote and press "DISK SKIP" repeatedly until the desired DISK indicator [1-5] lights up.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
1helpful
Child Lock Sony DAV-HDX265
  2. Press the Up arrow ^ or dowm arrow v repeatedly until "CHILD LOCK" appears.
Regards,Tony
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, [email protected]
Sony home theatre model dav-hdx265
hmmm..didn't know you could do that? Do you have the user manual on hand?
 Grubhead
Grubhead
SmartAviator
SmartAviator
