SOURCE: Westinghouse LTV-32w4 HDC widescreen DVD Combo
Unfortunately this TV will not support 576i, the standard PAL resolution and therefor you will not be able to use a PAL TV tuner with it. The only other options are to use any HD device such as an HD TV set-top box or HD DVD player as these will connect to the TV via HDMI at an HD resolution, alternatively you could use your PC as a TV tuner (if it has a TV tuner inbuilt or attached) as your PC will send a VGA signal to the TV at 1360x768.
SOURCE: Westinghouse LTV-32w4 HDC No signal how do i
Hello, this all depends on what input signal you are trying to see, there is differnt ways to reset the signal, I would love to help you resolve this issue personally, please email me at [email protected] so I can better assist you. Also if my assistance is helpful please rate my help on this website.
SOURCE: how to remove dvd drive for Westinghouse LTV-32w4
http://www.retrevo.com/support/Westinghouse-LTV-32w4-HDC-TVs-manual/id/278ci973/t/2/
First you would have to get a service manual, this shows you all you need to know about the unit. Without it, it is very difficult to even remove the case. but once inside, it is basically a simple task, to find the drive, remove the fastenings, and the Cable, obtain an EXACT replacement HDD, and reverse the procedure, it may pay to format the HDD first, FAT32, I believe, although your manual will be more specific.
