? 0:55 www.youtube.com/watch?v=Ef0WwaTXgtQ Oct 6, 2010 - Uploaded by natasmanda01
Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
c4000
The Problem: inside the laser unit Polygon motor synchronization problem The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
how to fix error c6020...1st step is go get a gasoline and a match and then pour the gasoline to the kyocera and then lit it with your match stick...it will automatically restart..for more details contact your kyocera supplier.
Throw it away
