the menu button doesnt do anything still says no signal............?????????????
The menu button does not work!!
The volume has to be set at 0 and you have to use the buttons on the tv not the remote. And you also have to hold the menu and channel up button at the same time.
Thank you thank you Thank you. It work. Bless you : )
I hold the menu and channel up button at the same time and nothing happens. Any suggestion?
Well Even mine BROKE AGAIN.
It Has something to do with the REMOTE!!
Below are some successes with the remote noted but I have not found an exact "this always works solution" Yet Also I think the software updates through the AIR some how I can't prove it yet without a decompiler but the size of the firmware check sum HAS CHANGED over the years. How can that occur ????? You would think the MFG would release a workable solution by now. Geezzz very rude of them.
It lock up mostly for me when I try to hook up my Mac via HDMI it has not happened again since I stopped hooking it up that way and it will lock up when the computer goes to sleep but the screen saver mode is ok.
The last time I took the whole unit apart drained every cap of power reseated every chip. Re soldered and re-flowed every connection I could get access to. It still was broke. Then I left it off for 6 months UNPLUGED and it still was dead.
I finally was messing with the Remote and took it apart and the volume was Stuck and a few other buttons and then I changed the batteries and then I could factory reset it through the front panel and the the remote together. It has worked for the 8 months or so and I have only used over the Air HD TV. I gave up on it for a multi use Screen like the MFG brags about.
When I can't reset this next time I am going to shoot a you tube video of me shooting it!!! With a 50 Cal at 800 yards with stick on bang targets!! DON"T BUY THIS TV FOR EVEN 10 BUCKS AT A YARD SALE IT IS A POS!!!!!
By
yulie1026
31 days ago
I also have this problem. Also, if I switch the input to PC or HDMI, it will no longer allow me to go back to AV.
AV itself doesn't quite work. When I turn on a peripheral, the TV seems to register the machine, but doesn't properly display it. For instance, if I turn on a game system, the screen switches from "No Signal" to grey. Another interesting thing is that when powered on, the intro screen that is usually blue displays as grey.
I'm chalking it up to a software issue, so my solution would be to find a way to reset it to factory settings, but I can't find any way to do so in the manual or online.
