Same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
I cant get the volume to go louder. It's all the way up to 100 and i can barely hear it. It sounds like it's in mono and not stero mode. I've been all through the menu and i cant find anything that helps.
I have the same problem-I have to unplug the tv then plug it back in in order for it to come on.
MY ILO LCT27HA36 TV won't come on, it just stays in standby mode The red led just blinks when you try to turn it on
My ilo lct27ha36 does not come on by pushing the button. I have tried unplugging the tv and plugging it back in and it still does not work.
