Model - WM-1371 FHB
Fault Code OE
Pump not running / not pumping out - stops half way through cycle (before spin but after wash).
If run from Rinse / Spin - OK until pump out.
From LG Manual:
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
BUT!!
It isn't blocked - am looking at the pump next!!
Cheers John
Thanks for your help, which I picked up after I had fixed the machine, but which was never the less most helpful, and right!!
To get at the pump easily, you have to turn the machine upside down - don't hesitate unless it is still full of water ;-)
Pumps go regularly so there should be a fairly quick and easy way to remove/replace it - don't simply start undoing every screw you see. there will be some quick release clip and a couple of screws. You will also have toi detach the hoses - watch out for those super tensile hose clips - I used Mole Grips, judiciously adjusted.
Pump comes apart easily (3 screws) clean it out thoroughly taking care not to get water into the electronic bits!!
Remove **** (mine had a 6" piece of thick black cord wrapped around the impellor) reasemble and hey presto!!
Cheers John
on washing cycle code OE keeps coming up.checked drain hose,pump and filter.all good.what else could it be?
