Save yourself the time and frustration and take it to a reputable watch repair shop and let them adjust your band for you. Could be screws or could be pins! Plus if anything small drops you might not find it again!
As you pull the mainstem out, there will be a position, a 'notch' if you will, whereby as the hour and minute hands are rotated the date will change. Rotate ONLY clockwise, and when the desired date appears, be sure to turn an additional 360 degree turn on the hands if you are setting the date in the afternoon. Otherwise, the date will lag by 12 hours.
Maybe you can try above link to contact Swiss Wenger for the repair of your watch. It's best to send your valuable watch to its Authorized Dealer for repair.
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.
