To need help from some experts Mytag model: MDG5500AWW\r\nSerries: 67693467EV this is a mytag gas dryer: Its panel light is on but It does not work when you press on them. i tried to unplug and plug the power cord couple times to get lucky work one time and after that load it does not work agian. First, how can i retrieve the flashed trouble code and what do you think the problem? do you think easy to do it by myself (a handy man)? Thank you for your help. best regards, Don
SOURCE: Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
SOURCE: Flame will cut off in 30 second
check the loose blower wheel and lint in the filter housing phenom associated with these dryers. The operator coils will get hot and quit and cool down after several hours and work again making it imposible to pinpoint a solution. Replace those coils. $20 bucks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a Mytag Dryer MDE9606AYW
Unplug the dryer, open up the top panel. check if the belt is broken . replaced it.
SOURCE: may gas dryer is not heating
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
789hj
Hi all,
I found the answer by myself which maybe help for somebody if you have the same problem or something else. On my Maytag, I opened 4 screws on top and 2 screws on back of top metal plate. I found the instruction sheet troubleshoot problem. It tells you how to enter service mode, diagnostic test, membrane pad check, & diagnostic code...v.v.depended on your Maytag 13 key membrane or 15 key membrane, it is a different key pad to enter. My code is 08_short key. I used Ohm meter to test membrane pad at j7 connector_ok; then, put back to run the membrane pad test is ok too; I resit cables; then, clear the code. it is working fine now. The j7 connector of membrane maybe loose or membrane stuck before. but, at least I know how to diagnose if it has problem agian.
Best regards,
Don
