Dryers Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It doesnt heat up - Dryers
electronic & computer repair& servicre
Level 3:
  • Dryers Master 12,061 Answers
  • Posted on May 19, 2010
Dryers Master
Level 3:
Answers
12061
Questions
0
Helped
4006155
Points
36390
Http://136.166.4.200/contents/Laundry/DLE8377/DLE8377_Service_Manual.pdf
Above a service and troubleshooting manual above, use this to troubleshoot your issues.
2answers
Why is my lay z spa not heating?
if the heat light comes on but doesnt heat bad heater element if red heat light doesnt come on need new temp sensor
Aug 31, 2014 • Pool & Spa
Amana heat pump doesnt come on.
sooo many possibilitys. turn it to heat NOT EM HEAT. usually a low voltage issue. unless experianced i say leave this one to the pro's
Doesn't overheat, but losses coolant. also has oil in resivior. heater doesnt blow hot air
sounds like bad head gasket or intake manifold need compression test thing that scares me is oil in water resivoir
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hfjjf
3helpful
Our microwave has power, turns on correctly but doesnt heat
our microwave has power, turns on correctly but doesnt heat. It sounds like it is heating but it don't.
1helpful
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 • Dryers
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Top Dryers Experts
john h
