I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
