You can download the driver for your camcorder from the following link.( http://downloads.phpnuke.org/en/download-item-view-z-m-v-z-a-g/PANASONIC+NV-GS22.htm ).Please don't forget to rate me as ' helpful ' if satisfied.
You can use an USB analog to digital converter for the analog outputs or the firewire/DV/iLink connection for the digital output, with the capturing software you can then have your videos on files or disks.
This type of camera usually downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is used only for stills.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My Samsung mini-DV camera came with the correct lead. I did not need a driver, just some sort of video editing software that can accept input. Even Windows Movie Maker that ships with Windows will work.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
You can download a manual for this camera by enterring the model number in this webpage.
