Hi.
Error DR is door latch error.
Check the door lock, and ensure that it it closing and opening properly.
Disconnect power cord or trip circuit breaker for one minute to reset the error code.
If the error code comes back, then the door lock may be faulty.
The door lock may be tested removing it from the washer and reading Ohms on the terminals to ensure that it is opening and closing the circuit. An alternative way to test the lock is by jumping it, if error comes back with door latch jumped, then fault is on wiring or controller board.
Here all parts and diagrams for this appliance.
Regards.
Ginko.
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
