Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
On ceramic hob, 2 rings only worked intermittently, I cured this by pulling apart and squeezing the spade terminal to make them tight. I think the vibration from the fan oven below had caused most of them to work loose.
