The instructions are in the "Memory" section starting on the fourth column of the manual at
http://www.home-electronics.net/USER-GUIDES/29322_DOM_ES_CD_IB.pdf
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
living solutions desktop phone (model unk) programing.
turn on with speakerphone button
hit store button once
enter phone #
hit memory button ( where number is to be stored) once
hit auto button once
to dial stored #'s
kift reciever or turn speakerphone on
hit auto once
hit memory button (where # is stores) once
wait for completion of call
here is the owner manual , to much to type , but start at storing a phone number in MEMORY , start reading at the word MEMORY in the user guide .you need to list a phone number in memory and then assign a number to it for future speed dial , yet they use the term memory . can be accessed while on the hook or off .
I fixed this just now on my phone, while seeking a solution here.
- Do not do what you'd think... putting the phone and name info first. It looks like it will take this info but it won't. That's where the frustration comes from.
- Dial the PHONE# FIRST.
- THEN click STORE.
- Then click the location (A-C or 0-8... save 9 for 911 if you don't have a red emergency key).
- Then click STORE again.
- Then type in the phone number again... this works, though there's probably a way to do it w.o putting in the number twice... but since it works, don't sneer at the free advice :) LOL.
- Then click Store
- Then type in the NAME
- Then Store.
Done. Repeat for other names/numbers. Now that you have it down, you can figure out how to do this without entering the phone number twice... but since I have a busy day, I'm just doing it this way.
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works) To program: 1. press speaker or lift handset. 2. press STORE 3. dial the number to be stored 4. press MEMORY DIAL 5. press location (0-9 on keypad or 1 of the 3 emergency quick dial) 6. press speaker or hangup. To dial emergency numbers: 1. press speaker or lift handset. 2. press any of 3 emergency quick dial To dial stored numbers: 1. press speaker or lift handset. 2. press MEMORY DIAL 3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Store as many as 12 numbers in memory for easy dialing.Three can be stored in the Emergency Quick Dial locations,and nine additional numbers can be stored in the numberedkeys (1-9).
STORINGA NUMBERINMEMORY
1. Press SPEAKER (or pick up the handset). 2. Press STORE. 3. Dial the number to be stored (up to 16 digits). 4. Press STORE button. 5. Press a Memory Location (1-9 on the keypad), or anEMERGENCY QUICK DIAL button. 6. Press SPEAKER (or hang up the handset).7. Record the phone number on the memory directory(located under the plastic cover).
ADDINGAPAUSETOTHEDIALINGSEQUENCE
Use the REDIAL button to insert a delay in the dialingsequence when storing a number, for example, when youneed to dial 9 to get an outside line.Press REDIAL at the point in the dialing sequence in which apause is required.
CHANGINGA STORED NUMBER
Change a stored number by replacing it with a differentnumber.
DIALINGA NUMBERFROMMEMORY
You can dial numbers from memory when using thehandset or speakerphone. When you get a dial tone, pressthe MEMORY DIAL button followed by the memory location(1-9) for the number you want to dial.
