Have a Fuji Finepix F420 that has had no accidents or falls. One day I
figured out that it works only in Play mode but do not take picture or record video.
works fine in play mode but turns itself off when trying to take a picture or record a video.works fine in play mode but turns itself off when trying to take a picture or record a video.
i was taking snaps, during this the camera automatically show black in LCD i turned off the camera and restart it but the problem was same. Then i switch over to movie button the problem was same LCD was black and not focusing.i was taking snaps, during this the camera automatically show black in LCD i turned off the camera and restart it but the problem was same. Then i switch over to movie button the problem was same LCD was black and not focusing.
Ok in play mode. Turns off when try to take photo. Changed battery get one flash and then diesOk in play mode. Turns off when try to take photo. Changed battery get one flash and then dies
You can't post conmments that contain an email address.
I have the same problem. no fall or accident but problem is same. i think it is common problem on finepix f420 and fuji has to find a solution for it. the guarantie of the camera expired and after that the problem happened. fuji has to repair them for free because the source of the problem is the machine. so it is fuji. not us !!!
My camera now works!!! I totally discharged the battery using the facility on the camera and then fully recharged. The camera now works as new. Hope this helps.
All you can try is to remove the batteries, wait for about 5 minutes the replace them. If it's not working, it seems to be a problem either at the CCD/CMOS sensor, or at the lenses zoom mechanism.
Hi there, First of all i like to say its a problem of your lens guide pin. Its happens during dust or drop down camera or lens pressed by turn on mode. Just try this.
1. Turn on the camera and make it camera mode then clean the external lens area & make sure there is not dust or any scratch.
2. Reset the camera and remove the memory card. Now turn on the camera with out the card and see the result. If not success then let me know. Thanks.
Hello Jrmb, I would like to know what mode are you clicking these photos
in.. because overexposure is due to either slow shutter speeds or large
aperture. Try setting the camre mode according to the surrounding light
conditions.. for example, no need of flash when you are clicking
pictures in broad day light, instead of setting the camera on Auto
mode, try using Portrait mode for short distance (5 to 6 meters away)
objects etc..
Let me know if that fixes the issue.
And important .. Do not forget to rate the solution :)
yes ther is no problem using Ni-MH batteries, as they do not have a memory effect they will be better (subject to your charger), you can get the Fuji Finepix NH-20 batteries (wj=hich are NIMH) here - Fuji Finepix F420 battery
i have the same - no solution i'm afraid as this is a problem with the memory on the camera, rather than something which can be set in the service mode
