Washing Machines Logo
A
Anonymous Posted on May 14, 2010
Washer will fill spin and drain but will not wash...
YOGENDRAN K
Level 1:
New Friend:
  • Contributor 57 Answers
  • Posted on May 20, 2010
YOGENDRAN K
Contributor
Level 1:
New Friend:
Answers
57
Questions
0
Helped
12971
Points
96
  • first check the motor power supply whether it is fine or not
  • next check the motor coil whether it is working or not
  • If both are ok the motor power supply and coil is fine means you are suppose to check the pressure starter since it is giving the signal to the wash motor to run
  • kindly change the pressure starter to solve your problem
2answers
I have a GE washer model# 175D2750G041 after the washer fills up with water and starts to spin to wash it makes a awful noise but only when spinning to wash not spin to drain water . what could it be
Your question is confusing. A washer doesn’t spin when it washes. It agitates. A washer fill with water, agitate, drain then spin water out. Please reword your question.
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
2answers
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Our washer filled with water and will not drain. There is no action at all. Water just sitting in washer. Washer will not work Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
3helpful
2answers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
1helpful
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Washer stopped after wash. Would not drain or spin. Will fill.
Hi, can I get a Model# and make so I can try and assist you?
Vic
Top Washing Machines Experts
john h
