Ricoh Aficio 1232C Color Copier Logo
Anonymous Posted on May 20, 2010
I need enter in factory service mode to enter serial Nº by code SC195 in aficio 1232.
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on May 23, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
6416
Points
30
Press the clear mode key and use the key padto enter '107'hold downe clear\stop key for 3 sec enter the service mode and press on the touch panel sp mode and you can work what ever you like
  • cd70786 Mar 17, 2012
    It is Good to help the Technician to solve problem.
    I like it Sir.
    Thanks for give it at on Line.
1helpful
Service call SC195
DF gate assert error.Try reset the code by open/close the front door or enter in the SP mode and turn OFF and wait 1 minutes and turn ON the copier.
I need the code for my opel corsa grundig car200 (D) with the serial nº GM0200W59119564. Tkanks.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
1helpful
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
2helpful
3answers
Service Code - Fucntion Problem within the copier - Code SC541 Serial # of Mach J0122404128
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
if that fails, contact technical support. It will be necessary to replace the fuser roll and the thermistor
Copier mp3500 rex rotary ,i want to remove the authentication ,it displays sc548 contract serial no of march M2772901444
This a fuser (hot section) error code that need you to enter service mode to clear, -Carl
36helpful
3answers
2helpful
2answers
Ricoh Aficio 1045 error message SC726
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
10helpful
3answers
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Code SC195 Functional Problems
Enter SP mode: Press Clear (yellow) button, 1 0 7 and press and hold the Stop (orange) button for 3 secs. Then switch off and on again.
SC 195: Serial number mismatch
Serial number stored in memory is not correct.
Enter SP mode and check the serial number of the machine with SP5-811-002.
If the stored serial number is incorrect, possible causes are;
  1. NVRAM defective
  2. BICU (Main board) replaced without original NVRAM
Good luck and please rate me, thanks.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
