Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Treadmill stop then display an error speed
Treadmill stop and display an error speed of treadmill lifefitness 9500HR. whats the solution to that problem, can you help me
  • Anonymous Mar 20, 2014
    treadmill turns off, over speed error displayed
  • Alma chee
    Alma chee Aug 08, 2014
    please see a handy diagnostic test mode guide here:http://www.treadmillsrepair.co.uk/2014/0...
    New Friend:
  • 69 Answers
    President:
  • Life Fitness Master
  • 832 Answers
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
Posted on May 21, 2010
6ya staff
SOURCE:
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Sep 23, 2013 | Life Fitness Exercise & Fitness
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
i recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
Sep 23, 2013 | Life Fitness LifeFitness 9500HR Treadmill...
I have 9500HR Treadmill Lifefitness, Lift keeps increasing when pushing the down button.
RUN the software calibration for easy diagnostic and fix it. Go under the HOOD motor, and follow the steps.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
How do I reset a lifefitness Treadmill 9500HR from miles per hour to kilometres per hour
    • 1
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
    • 2
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
    • 3
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.Sincerely.E.CUADRAMANAGUA, NICARAGUA C.A.
Oct 11, 2011 | Life Fitness 9500HR Next Generation...
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
Aug 01, 2009 | Life Fitness 9500HR Next Generation...
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
679 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
