Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Put the eyepiece with the largest number written on it into the focuser, do not use the 2x barlow. TRY AGAIN-- during the day time and practice focusing on a distant object.
The end with the FOCUSER is the UP end of the tube-- the mirror is on the bottom of the tube. Many beginners mount these BACKWARDS.
50V500 ONLY GHOST: May be described as "Out of Convergence" but ghost is still attached to main image. CONDITION: A "ghost image" appearing to the left or right of images in the picture.Can be varying shades of a primary color (red, green, or blue) as well as gray.Can easily be seen in the 4 x 3 mode, at the edges of the picture. CORRECTION:
To correct the problem, please do as follows:
Access I2C Menu. (See page 57 of the Service Manual).
To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
Figure 1
BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
Be sure to press SELECT after each change to SAVE the new Data.
Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
Figure 2
Move the joy stick to the right to cursor right once.The next page will appear with the word GHOST highlighted.
Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3.You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
Press the "EXIT" button three times to return to normal picture.
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either. Each pixel is individual and the problem will most likely not spread.
This is called diffusion, it is caused when the power supply voltages do not match what the plasma panel requires. Unfortunantly this is not something you should do yourself, high voltage danger and possible damage to the tv if you are not very experienced with this repair. A technician can however read the voltages and adjust them to specifications and this will get rid of the dreaded red dot diffusion. Very common in samsungs but not that expensive of a repair. Hope this helps.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
