It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
SOURCE: Kyocera 3820DN
If the neck of the waste toner box has toner on it it will think it is full wipe inside of neck stem with tissue.
Turn off and on, does waste message disappear? If it does and you still have jam problem post back and I will help you solve it too
SOURCE: Replaced the waste toner box.
re check for the toner inserted, be sure that protected plastic remove. shake and insert again.
Testimonial: "so simple; feel so stupid!"
SOURCE: Wast Toner Box is filling up quickly.
You say there are colors in the box but the 3800 is not a color printer. If it is one of the desktop color printers there is a setting change that may help. It is a service mode setting called "T7". If you print documents that don't use much toner this setting will reduce what is dumped in the bottle during operation. If you call the Kyocera End User Help Desk they can remote in and make the change if they think it will help. 800-255-6482
