HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
A
Anonymous Posted on May 19, 2010
How do I scan a document on a HP Laserjet m1522nf...
How do I scan a document on a hp Laserjet m1522nf printer?
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Aug 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
16632
Points
88
Install full software, download from www.hp.com
2answers
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
I cant find any drivers for hp laserjet m1522nf mpf fo in oder to make it scan,as well as the EWS,Nad fax drivers
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
I WANT DRIVER FOR ( HP LaserJet M1522nf Multifunction Printer) MY OPERATING SYSTEM IS WINDOWS 7. I WANT TO CONFIGURE IT FOR NETWORK SCANNING.
JUST GO TO THE HP SITE OF U R COUNTRY AND SELECT THE PRINTER SPECS AND DOWNLOAD IT. BUT DO REMEMBER THAT NOT ALL PRINTERS OF HP PRINTERS ARE COMPATIBLE TO WINDOWS 7,AS THEY R YET TO HAVE DRIVERS LISTED IN THEIR SITE .PLEASE CHECK ON THEIR SITE
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Al
1helpful
My HP Laserjet M1522n will only scan one page. How can I scan a multi-page document?
Call hp tech support, you need to uninstalla dn reinstall the software. You may have to replace a dll file.
Al
1helpful
How can I scan with the HP Laserjet M1522nf?
Try rerunning the installation disc, you will find and option that reads "install more software, install this a restart your computer
1helpful
How to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
k24674
Grand Canyon Tech
Grand Canyon Tech
